I'm in the market for a new HSF which will hopefully prevent overheating and crashing. I'm looking at the Xigmatek HDT-S1283 but my main concern is that it wont fit.
i have the ASRock 939Dual-SATA2 with Dual Core AMD Opteron 165 with stock hsf running vista ultimate 64. housed in an Antec Sonata.
While running prime95's torture test the cpu heated up to 100C and the computer crashed. I'm thinking that the xigmatek s1283 would solve this problem. do any of you know if this hsf will fit in my case/on my mobo?
if not, are there any alternate solutions for under $50?
Thanks in advance for any input.
