please help!
lillimon04
ok i just bought the e6300+ecs p4m800pro combo, and i put it in and use the old windows worked great with all hardware, yet kinda choppy in wow, so i formatted and installed windows media center edtion instead of pro. and now my pc wont recognize my x800xl or even onboard video, i tried to install vid drivers and said the video card was not seen. and then tried to install onboard video drivers and it says cant find it. so wat should i do?!
ok i reformatted again and fresh windows and used no vidcard just the onboard,, i found it and i dled drivers for everything, then i disabled the onboard vid and installed real vid card and went back to th same error. can anyone help me? please!! i really wanna use my e6300!!!!
OK, if you installed the driver CD included with the computer then you should have installed the chipset drivers.
These will seem like really basic questions, but I just want to make sure (I don't mean anything condescending): Did you plug the power back in for the video card? Do you have the monitor plugged into the video card and not the motherboard video port?
yep exactly everything, i was thinking maybe i should install the vid card while the onboard video is still on and then install drivers for my x800xl and delete the onboard ones? i have never ran into any problems like this one before.
Well, I have that same mobo in my backup system. I used the on board video for a while and then eventually put a 6800 in the system. I just put the video card in and installed the drivers. I didn't need to uninstall anything.
ok well on the box it told me the wrong version of the board and i dled the wrong drivers for the mobo, how do i uninstall all the drivers i did install? and maybe i should take the board back and exchange it for a new one?
If they were the wrong version, they wouldn't have installed properly anyway. It's probably not a big deal. You can remove the drivers from add/remove programs in the control panel.
Go to viaarena.com and download/install the most recent 4in1s and see if that helps clear anything up.
ya i did that a million times, and then i got atidrivers to hack into starting install but while installing the error came back up. so i think imma take the mobo back, i think i got a bad one. u think i should?
Did you get the .NET framework? You need it to install the ATI drivers.
ya i tried an fx5200, still nothing. i think i just got a bad board imma take it back tomorrow.
