I know I know XP Home networking issue about says it all but what I'm seeing is driving me nuts and I'm at my wits end. I have crappy little (but fairly new) Compaq machine with XP Home on it for my daughter which suddenly won't connect to our internal network at all. When I run ipconfig I get a message saying "The request is not supportted...unable to query host name." So I figured I'd try pinging the machine itself. When I ping localhost I get "Unable to connect to IP driver, error code 2". The NIC is installed, has all the usual items (client for MS networks, file and printer sharing and TCP/IP protocal), and shows as working correctly. I've verified the ethernet cable and port are working with another computer. When I disconnect the cable I get the standard cable unplugged warning so the computer is aware there's a cable connected. I figured the onboard NIC must just have some problems so I disabled it and installed another NIC I had which I know works. After install of the drivers, same story. Everything looks like it should be working but ipconfig and ping both fail. This computer is about a year old and has nothing on it but a couple kids games. It's never received email and has only visited about 3 or 4 websites (Disney etc) so the likelyhood of a virus is pretty remote. Like I said I'm at my wits end and I'm basically out of ideas. Any suggestions you might have would be greately appreciated.
Thanks,
Dane R. Vinson
Thanks,
Dane R. Vinson
