please help with raid 0 having bad problems
jeepnrocks
hello i have a gigabyte ga-k8nnxp motherboard with onboard raid. i correctly set up the raid with the onboard utility ( i have both hard drives on separate cables going into the 2 onboard ide raid ports (the 40 pin ones) one hd is set as master and the other as slave. the config accepts the settings but in the manual it says to copy the raid drivers from the cd direrctory iteraid. well there is a bunch of stuff in there and this is where my problem lies. i dont know exactly what to copy so i copied everything but the text documents (2 of them were 7 mrgs each so i couldnt put them on a floppy) and i even copied the contents of the winxp/2000 folder into the main directory
i get a message that says unexpected error with ...... dang cant remember the exact file. but when i tried it yesterday it worked and then went on installing but before it got to where i would format a drive it said please insert disk labeled iteraid drivers 8212 into drive a and when i did that it wouldnt accept it? canm anyone help me please ?
Raid 0 isn't worth much for most apps, video editing being a big exception. The only reason I use it at home is to merge 4 18GB FC-AL drives into one nice big volume. I don't have a RAID controller, so I'm just using the built in raid 0 in windows. All I put on it are games, and I usually load games w/ valuble save files (RPGs, long strategy games, etc.) on a diferent disk.
In theory it's also my target drive for my TV capture card, but I don't really use that except to watch TV live.
