Leto Atreides II
- Apr 28, 2017
I recently "upgraded" to a new motherboard, CPU, CPU Cooler, and PSU after I damaged my old CPU and motherboard. It wasn't much of an upgrade because I wasn't sure what components were damaged and I wanted to swap as few parts as possible so I tried to stick to my old LGA socket. Unfortunately, it turned out that I had to replace both the CPU
and motherboard (nearly everything). Still, I did net an upgrade from an I5 2400 to an i5 2550K CPU.
I've never overclocked before, but I'd like to now to get the most out of this CPU. I also learned that the RAM which I had was underclocked by default and I'd like to"overclock" it to run it at its stock rates. My new motherboard is an Intel DZ77BH-55K whose BIOS I updated to the latest version which is Intel Visual Bios.
Intel Visual Bios seems to be designed to make overclocking easy. But as I've never overclocked before and I'd like to be as careful and informed as possible, I'd like as much advice and information as possible first.
For CPU overclocking the Intel Visual Bios overclock assistant provides a simple slider which ranges from 3.8 GHz (default) to 4.5 GHz. As near as I can tell, however, overclocking with this slider ONLY affects the Turboboost speed. Is this a good way to overclock or the best way to overclock - to only change the Turboboost speed? If not,how would I go about it? I plan to run Prime95 for 30 minutes afterwards to test stability and use Speccy to monitor temps. Is there anything else I should do as part of the overclock process (I've never overclocked before)? Also, should I increase fan speed in Bios (and how do I do this - there is a cool simple setting in visual bios I'm considering)? At stock speeds it's already running in the 70's under load.
This is my RAM: 4x4GB https://www.newegg.com/Product/Product.aspx?Item=N82E16820233180
There is a slider in BIOS for RAM which I could slide to 1600. But there's also a Performance Memory Profile drop-down box which has an option for an XMP-1600 profile. That profile and the slider at 1600 have very different values. Which should I use?
Finally, how much will these overclocks increase my power usage? I only care because I actually downgraded my PSU from 750W to 650W (b/c a 650 was the spare I had lying around). Fortunately, I think 750 was way more than I needed before and 650 might be more than enough now. Thanks all for any advice you can give.
