PLEASE HELP WITH NEW MOBO/CPU(caps lock broke)
Kami
This all happened a while ago, and I wanted a computer that could play HL2. This all started around september.
I bought a chaintech ZNF3 motherboard a while ago, along with a new sempron 3100+.
When I first assembled it, it worked. I played some Halo PC, and loaded Itunes...I miss not having to wait 5 minutes for itunes to load a song...
I paired this mobo/cpu with PC2100 RAM, seemed fine.
About two days after this, Iinstalled the latest CAT drivers(CAT 4.10 at the time) for my 9800pro.
The thing didn't reboot.
It made one beep, and then just some kind of weird mechanical sound(coming from the motherboard).
I've tried SO MUCH SHIT to get this computer to work again, I literally tried to get it running with all of my free time for about 2 weeks.
This was after I RMA'd the motherboard and CPU to zipzoomfly, and having them tell me those components worked fine.
I assumed either my RAM, PSU, Hard Drive, Video card, and even maybe my CD drives could all be at fault.
I bought a new PSU(raidmax, ha), and the same thing occured.
I'm about to try my old radeon 8500LE to see if this is possibly a graphics card problem. I'll update on that tommorrow.
I've called Chaintech, and they said it was a BIOS problem(they sent me a new BIOS chip which Iinstalled only to have the same problem occur.
I don't want to buy RAM, as it's expensive, I'm 15, and have too much shit going on in school to get a job. I'm wondering if I should ask santa for some good RAM for halloween.
My family is lower middle class, and I christmas is usually the time I'd get money and spend it on things other than computers...I don't really want to have to get new RAM for this computer to work again.
I'll describe the problem to the best of my memory:
I turn on the computer, it instantly does it's weird beeping, and usually doesn't detect my CPU at all. Sometimes it does, and it gives me a "KEYBOARD NOT CONNECTED OR POSSIBLY DISABLED" message. Sometimes if II press F1 a lot it gets to windows, but I can't use my keyboard.
Any other questions just ask me, and I'll try to help you help me.
I'm on a 433mhz celeron righrt now that has problems doing anything more than internet explorer. Please, please help me...
Check the manual on your mobo for the beep code. Sounds to me like a memory issue which it seems you have feared.
I have heard of alot of bad BIOS batteries floating around but they are a cheap fix.
Try this site for info:
http://www.omnicast.net/~tmcfadden/guides/build/index.html
The guy is extremely helpful so email him if you have to or post in the proper help forums over at anandtech.
I posted this on anand, and I'm about to play around with the parts again.
Thanks for your help, not many people cruise this board, I didn't really have any idea where to put this topic. No one seems to go to general anymore.
I can pretty much rule out my graphics cards, and hard drivers, correct? That would mean that I could try the following things before buying new RAM/PSU/Video Card
Try 8500LE
Change batterey
Change PSU around
Anything else I could do before buying new RAM? If the RAM doesn't work when I buy it, I'm going to be throwing this stuff out of a window...
First start in a logical pattern instead of trying random things. Start by doing these three steps, then work one paragraph at a time until either you hit the problem part or you're back up and running.
1. Remove ALL drives from the system, disconnect the power and data cables
2. Remove ALL cards from the system including your video card
3. Remove ALL the RAM
Plug it in and turn it on. You should get one long beep, a small pause then another long beep and so on continueously. This is good, it means that everything passed the POST up until the RAM test. If you don't get any beeps, you're looking at either a bad motherboard (unlikely after an RMA), bad CPU (also unlikely) or bad power supply (most likely in your case).
Add one stick of RAM in and turn it on. You should get several beeps. If you get the long beep error, that RAM is probably bad. Turn it off and move the RAM to another slot, rinse repeat until you either put the RAM in all the slots or it stops giving you the long beep error. If you put the RAM in all the slots and it still gives you the long beep code, the RAM's bad.
Put your old video card in the system with only 1 stick of RAM and turn it on. If you get a display, let it finish posting and try and boot. If it doesn't give you a display or gives you several beeps like in the last step, the motherboard is bad (specifically the AGP slot).
Add another stick of RAM back in at this point, turn it on and see if you get a display again. If not, the second stick is bad. Skip this if you only have one stick of RAM.
If you're at this point, remove your old video card and put your new card back in and turn it on. If you get a display, you're probably ok and can start adding parts back in ONE at a time. If you don't get a display, your video card is bad.
Thanks for the help, I'm now posting from my sempron.
I'm not sure what I did differently, only major thing is I switched in my 9800pro for my 8500LE, and followed your directions.
I'm having a few weird problems with windows though, I'm going to end up reformatting the drive after I check all my hardware.
Once again, thank you for the help, you're a lifesaver.
Kami said:
Holy sweet god damn this is fast...
A semperon 3100 + is equal to the speed of what Athlon? In general how fast are semperons, I have always thought of them as being slow... Just wondering..why didn't you get a cheaper Athlong like a 2600+ ?
It's the K8 sempron 3100+, so it's about as fast as the Athlon64 2800+.
I've been on a 433mhz celeron for about 3 months, thats why I'm so amazed...
