Please help with dual core amd and Nvidia ntune
logan006
Sys info:
EVGA nForce4 SLI x16 NF47 mobo
AMD X2 4800 @ 2.4ghz
2-wd raptors
xfx7900gs
Set up a new mobo to get pci-e and away from agp,( i know i know im way behind.)
Installed the lastest ntune and drivers and all the good stuff. After all was running along just fine thought i'd try the auto sys tune within ntune. Did a 3hr run and had a 2.8ghz ovclk which was great. Then i install AMD dual core optimizer. Went in and ran ntune auto tune again. It ran for about 45min and did a total lock were i had to reset and as soon as windows loaded and ntune restarted it locked and i reset again and again until i could stop ntune from auto loading. After all this, windows is reading my cpu at 1000mhz-mutiplier x5 and so is my system info and CPUZ and anything else that shows hardware specs. Now at sys post Bios are fine, settings show mutiplier x12, 2400mhz dual core x2 4800 etc. But when XP loads it's like its reading only one core. My question is how do i get Xp to read the right cpu freq?:confused:
