Please help with Asus Commando issues
I just received my Asus Commando, E6600, tuniq tower and G.Skill DDR1000 (rated at 4-4-4-5 @2.3V) memory. I installed everything and widows installed without a hitch, but I can't even maintain stability for more than a minute using prime95/orthos when overclocked. I overclocked to 3.2GHz and prime95 errors in less than a minute. I have read through this forum and xtremesystems.org's forum and know that most people can hit mid 400's FSB with some tweaking and remain stable on air cooling.
I installed the tuniq tower following the directions perfectly and hand tightened the four screws until I almost couldn't turn them anymore. Is that too tight? The fan inside the Tuniq faces the rear and blows air out the back of the case. Is that correct?
Here were my settings when overclocked:
Using Bios 803
Spread spectrum - off
PCI clock sync - 33.33
PCI express frequency - 100
DRam - 1:1 (533)
CPU Vcore - 1.45
FSB Voltage - 1.4
NB Vcore - auto
Memory voltage - 2.3 (per G.Skill specs. I have the DDR1000 stuff rated at 4-4-4-5)
DDRII Channel A, B and Ref voltage - all 3 at auto
SB Vcore - 1.5
SB Chipset Voltage - auto
ASUS C.G.I. - auto
Static read control - auto
Cas Latency - 4
Ras to Cas - 4
Ras Precharge - 4
Active to Precharge - 5
Write recovery time - 6
DRAM TRFC - 42
DRAM TRRD - 10
Write to Read - 10
Read to Precharge delay - 10
Write to Precharge delay - 11
CPU ratio CMOS setting - 9
C1E - disabled
Max CPUID Value - disabled
Vanderpool Tech. - disabled
PECI - disabled
Sorry for the long list, but I want to get this issue fixed. Temps never got higher than 50 degrees Celsius using core temp (case temp was around 40). I used artic silver 5 as the thermal compound.
Does anyone have any suggestions?
Thanks!
