Please help this is very strange
SuperCell
I'm attempting to burn some music onto a blank CD. I purchased a Roxio software program, and I know for a fact that I have a burner drive. At first everything seemed fine. It would apparently burn the music to the CD, and I could remove the CD and re-install it, and it would play the music back just fine on my computer.'
But when I put the CD in an actual CD player, there is absolutely nothing.
Any information would be greatly appreciated!
Okay if this helps, I think all the tracks are in wma format. Maybe that's why they won't play on a normal CD player? What are my options here?
What kind of file formats...
Are you making sure your mp3 files are being converted into .cda files. Typically only around 18 or so will fit on a normal 700MB cd.
Oh well make sure you select audio cd in the Roxio menu, and it should convert them into cda, if Roxio supports wma => cda, which I am pretty sure it does
Thanks for the help. I've copied the music to my computer using Roxio instead of windows. It copied it as MP3, but after attemting another burn, it worked fine this time. Maybe Roxio converts it into cda???
