Please help review new build
SeattleJo
Thanks for looking. I'm trying to put together a system for heavy Photoshop use. Little to no gaming. I'm a complete noob. I've read as much as possible here, checked reviews at new egg etc. but I'm afraid much of this is still over my head. Most likely buy from Ava Direct. The memory is what came with the standard Ava config, I'm not sure if there is a better choice, read that the mobo was picky. I don't plan to OC. Thanks so much
- Antec, Performance One, P180 Black Mid-Tower Computer Case, ATX, 450W PSU
- ASUS P5N-E SLI, LGA775, nforce 650 sli, 1066mhz fsb, DDR2-800 8GB/4, PCle x 16SLI/2, SATA raid 5/5, HDA, GbLAN, FW/2, ATX retail
- Intel Core Duo 2 E6600 2.4GHZ
- OCZ , 2GB (2x1GB) Gold GX XTC PC-2 6400 DDR2 800MHZ CL 5-5-5-12 SDRAM DIMM, Non ECC
- eVGA e-Geforce 7600 GS, 256mb GDDR2, PCle x 16SLI, VGA + DVI, HDTV/S-Video/Composite out, fanless, retail
- Western Digital 74gb raptor (for OS and applications)
- Seagate 500 GB Barracuda 7200.10 Sata II. 300mb/s,7200 rpm,16mb cache (for data)
- Lite-On SOHC 5236k Black Cdrw/DVD combo drive, 52x32x52x16
- Samsung super writemaster, SH-183L Black 18x DVD +-R/RW Dual Layer Burner w/ lightscribe, SATA, OEM
- Mitsumi black 1.44 floppy plus 6 in one card reader
- 8 channel audio controller (integrated)
- Interl Pro/100-s, 10/100 network card PCI
- XP Pro SP2b w/ free vista upgrade
- 500 GB external drive for backup
fore-go the raptor. go with another drive like a 250 :)
other than that, looks perfect :p
I can't remember exactly, but seems to me that people don't recommend the 7600GS, for some reason or another. Something about the GT being a better card for the money?
I could be wrong. Maybe someone else can chime in.
Gary
Omega,
Thanks for taking time to reply.
Why forego the raptor? Is the slight benefit not worth the extra cost in your opinion?
Omega,
horrible gain for the cost :p another 500 in RAID would be a better deal i think (not sure of the price of the specific drives you chose :p ) but id recommend a 250 for the OS and other stuff rather than that raptor :)
