Please Help! P5N-E 650i SLI Mobo Broken?
Mr. Sheep
Hey all,
I'm new to these forums but they looked like the best place to get some real good feed back, I hope someone out there can help...
I just built my first computer with the following:
Asus - P5N-E 650i SLI Mobo
eVGA - 8800GTX
Intel - Conroe E6600 w/ a Tuniq Tower for cooling
G. Skill - 2 x 1 GB @ 800 Hz w/ 4-4-4-12 timing
Cool Master - 850W Power Supply
Asus - CD/DVD Burner
and a 160 GB HDD
I got everything properly installed, powered up, and put together properly (or so I thought) hit the power button and nothing appeared on my monitor. I plugged in the mobo speaker wire and found out that a few seconds after power-up the mobo speaker starts this long 20 second solid beep, then stops for about 3 seconds, then starts the long toned 20 second beep again, with still nothing appearing on the monitor.
Can anyone tell me what's wrong with my computer? What did I do wrong? What am I missing? Please help me.
Thanks and Best Regards,
-Mr. Sheep
Yeah, I have power to everything. The video card fan spins, and evyerthing lights up and such.
-Mr. Sheep
Reseated the Memory?
You may want to pull all the cards and 'non essentials' out and try adding them back in one by one.
I've had similar issues from time to time during a build
Although I'm not sure exactly what the problem is, taking everything apart and then putting it back together seems to do the trick. Just pull the mobo, ram and all the cards, and reseat everything.
Good luck!
I have tried that. I put the video card in both PCI-E slots and moved the memory around, I even took off the cpu fan, pulled up the CPU cover to make sure the CPU was in there the right way just cause I was paranoid. I'm still getting the long beep folled by a couple seconds of silence and then the long beep again, over and over.
-Mr. Sheep
From some cursory searches on google, it sounds like repeated long beeps means a memory error of some sort. Have you tried booting it with only a single dimm or different slots? You might want to give each slot a try with a single dimm and see if you can at least get it to post.
Try putting the memory in one at a time in the Black slots.
You should have the PSU, Mobo, and CPU...eliminate the other stuff by not adding them yet.
I was just looking at this board on Asus' site but its no longer listed...at least where it was (775 Boards, 650i Heading...even the heading is gone). Wierd ... maybe they are redoing the site.
At any rate, try one Stick at a time in the Black slots.
I tried putting the memory sticks in one at a time in every single slot, and then two at a time in any combination of slots, pretty sure that I exhausted the memory thing. I will try and see if I can get some other sticks to test with to see if my sticks are broken (even though I bought them because almost no one had issues with DOA sticks). Oh well...
Any more tips or ideas would greatly be appreciated, keep the suggestions coming!
Thanks!
-Mr. Sheep
I do remember something about it being picky about RAM but I cant remember if it was this board or the other Asus I was deciding on.
Definately try getting your hands on another stick or two...see if it will at least stop beeping at ya.
Ya, this board is notorious for being picky about RAM, but I bought the best RAM that I could find that had the right timing and speed the motherboard wanted. I'm pretty sure it's not that the sticks are dead because... well... they still look pretty. But if I take them out completely and boot up I get some cryptic beeping signal from the mobo speaker saying that it doesn't recognize any memory in the slots.
Silly me... trying to build a good computer and thinking it will work...
-Mr. Sheep
Yeah the motherboard is really picky about wanting to boot for the first time with 1.8v ram.
There is a bios update to fix that (301 i think), but you kinda have to be able to boot in order to update it. Maybe find someone else that has some ddr2 ram?
I talked to the memory manufacturer and they said that the memory is definately compatible with the mobo. So does anyone else have any other suggestions besides memory? I'm at a loss now. Thanks again to everyone who has posted.
-Mr. Sheep
Try this - as others have suggested, you want to unplug everything from the MB - HD cables, CD/DVD cable, etc. pull the RAM, and the video card.
Remove the CPU, and clear the CMOS. Obviously nothing will happen since you don't have a CPU in it. Reseat the CPU, put your heatsink/fan assembly back on, etc. Use 1 RAM chip, and only your video card. Now try to POST. If it will POST (allow you to get into the BIOS, etc), turn it off and proceed from there. Add the second RAM stick, then POST, etc.
I hope this helps. It's frustrating when you get excited and start building and then roadblocks come up. Just keep a cool head and if you get too irritated, sometimes it helps to step away from it for a little while and try later. When you get really frustrated, sometimes you miss things and that's also a prime opportunity for costly mistakes to be made. Good Luck.
MrSheep
I had this EXACT same issue.
Thru trial and error I discovered it would only happen when I had a stick of memory in DIMM-0 or DIMM-1.
If you move the stick to slots DIMM-2 or DIMM-3 the board would post fine (but you are now SOL with any hopes of dual channel memory use)
RMAed and exchanged for a 680i. Drove me insane that the Northbidge heatsink was soooooo wobbly and that there were heatsink outlines, post holes, and labeling on the southbridge and voltage regulators, but no sink (WTH? 650i is a VALUE edition board?)
