Please Help? No Sound?
Chaintech VNF4 Ultra Motherboard
Windows Xp Pro SP1
Norton Anti-Virus 2005
Everything is updated.
No Sound out of any ports but the mic does work.
I had windows xp home sp2 before and i had a few probs with windows and then i clean whiped the hard drive and installed windows xp pro. Nothing is muted. Every Volume control is up. I have no yellow question marks under Device Manager. When i test the hardware under Sounds and Audio Devices it stats everything is working. The headphones do work. Is there anything i can do before i result to replacing the mobo and its brand new and everything inside the case is less then a week old.
-check the bios
-grab a cheap-o soundcard and test that.
with my MSI Delta2 board,the onboard NIC and sound didn't work.i didn't really care,i just used my soundblaster live! and my D-Link PCI Ethernet Nic Card.
