Please Help// New comp setup
Zeyne
Well about a year and a half ago now I baught an alienware (ya i know ) and ive been having major problems. Since may it shoots up temperature, the highest i think it was at was like 120 Celcius.. I just recently figured out it was most likely the graphics cards fan not working. Also the hard drive just died when I tried reinstalling the driver for the graphics card to maybe try and fix it (because it didn't use to do it till may and thought it might.. just turn it on or somethin ). Well I had to buy a new hard drive, but ive been planning on getting (building) a new computer for sometime now.
I'm a pretty big newb at this stuff (from messing with my comp though trying to get the damn thing to stop over heating and trying like 2 old harddrives (1 was broke and one had 325 mb total rofl) to work, I think I could figure out how to put one together), and I need help with what to get. This is what I came up with after doing some looking and stuff. If the links aren't allowed i'll remove em.
Case [Thermaltake Tsunami VA3000BWA] $105.00: http://www.newegg.com/Product/Produ...N82E16811133132
Video Card [Radeon X850PRO R48-PVD3] $249.00: http://www.newegg.com/Product/Produ...N82E16814131418
Processor [AMD Athlon 64 X2 4400+] $559.00: http://www.newegg.com/Product/Produ...N82E16819103546
SOund Card [Blaster Audigy2 ZS] $70.00: http://www.newegg.com/Product/Produ...N82E16829102178
Hard Drive [DiamondMax 10 300GB] $135.00: http://www.newegg.com/Product/Produ...N82E16822144421
Power Supply [PSCI-500BLK 500W ] $25.00: http://www.newegg.com/Product/Produ...N82E16817192002
Motherboard [nCK804Ua-LFS ATX AMD Motherboard] $114.00: http://www.newegg.com/Product/Produ...N82E16813137066
Ram [1GB (2 x 512MB) 184-Pin DDR SDRAM] $$114.43 http://www.newegg.com/Product/Produ...N82E16820141154
Total: $1371
Extras:
Speakers [Klipsch PROMEDIA ULTRA 5.1] $302.99: http://www.newegg.com/Product/Produ...N82E16836119106
Mouse [RAZER Diamondback] $43.00: http://www.newegg.com/Product/Produ...N82E16826153102
Cooling Stuff:
Fan 1 [CF4S-UGN 80mm Green] 1.99: http://www.newegg.com/Product/Produ...N82E16811998111
Fan 2 (Same as above but no deal)[CF4SL-UGN 80mm Green] 5.00: http://www.newegg.com/Product/Produ...N82E16811998102
I think I'm missing something for the cooling stuff :/
Hmm, what im most worried about is if everything will be compatible or not. Also, if there is any suggestions on lowering the price a bit
Thanks
-Zeyne
I have the case and it has 2 120mm fans that are loud. Those 80mm fans aren't going to help you.
- Your Power Supply seems increadibly cheap and I don't know how reliable it is. Don't skimp out in this item as you don't want unstable voltage in your computer. Get something from Antec or Enermax.
- There is a new sound card out from creative called the X FI, haven't checked the reviews yet but I would recommend you to do so.
- What about the OS, and Media Drive(s)?
For the moment this is all I could think of, I'm going to get Brunch.
