Please help(n00b)Which card
winamq
Hey guys I have no clue when it comes to computers. Here is a link to the computer I have
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00001661#N1036A
Says I have a 32 video card now. I have been playing Counter Strike alot (only game I play or ever will play). So what card is good for me, a 64 mb? And I looked into them online and there were so many that I have no clue on what I need. Also I don't want to spend over 150. The only reason why I want to get rid of the 32 (the one it came with) is because during gameplay my screen will flash red and then I can no longer see any text on the screen. I am thinking it has something to do with the card? Also about how much does it cost to install and hook up?? Thanks guys!
Go with a 9700 pro or 9800 pro (both ATI). ATI does better in CS, and anything over that is a bit much. You should be able to find cheap 9700 pros, which will run cs 1.6 well.
A used ATI 9700 or 9800 PRO is a goodt choice, but with only a 200 watt power supply, you may run into instability issues.
A great alternative that should be a nice complement to your system would be a used nVidia TI 4200 128MB or something faster (TI 4400 or 4600).
As a side note, you do not have a 32MB card actually. According to the specifications you listed, you have integrated graphics that shares system memory. Once you install the TI 4200, you should notice a little increase in overall system performance. You may have to alter the BIOS manually to make the switch, although some BIOSes do this automatically once the AGP card is detected.
Good Luck.
I came from a GeForce3 Ti500 64Mb and it ran Half Life 1 with vsynch on and never seemed to fall below the refresh rate of my monitor so it was as smooth as could be. I doubt counterstrike (which I've loaded up to look at, but never actually played) puts much more load on the card than Half Life. A Ti500 off eBay shouldn't cost you very much money at all.
He has a 200 Watt power supply in that computer and knowing HP it is probably some generic brand.
I suggest buying at least a 350 Watt Enermax or Antec power supply for your new 9700 or 9800.
If you plan on keeping your power supply longer than your new graphics card get a 430 Watt.
If he's purely and only playing counterstrike a 9700 or 9800 will be massive overkill, especially if he needs to buy a powersupply as well.
A GF3 Ti500 or GF4 Ti series card will be more than sufficient for this game and would probably run fine on a 200W PSU.
EDIT - according to this ( http://takaman.jp/D/index.html?english ) a Ti4200 only needs an estimated 37W
Replacing the PSU will have its own problems most likely. HP/Compaq are known for using proprietary PSU mounting that makes aftermarket upgrade a serious modification. With this in ind it really makes the GF4 the better upgrade choice.
guys, Freakin Ti4600!!???
You guys DO remember that voodoo banshees ran CS perfectly right?
A geforce4 ti 4200 will be WAY more power than he will ever need, and will be cheap.
Honestly he would be best off spending $35 bucks on a radeon 9200 128 meg off newegg.
I wouldn't get a GF4 ti4400 or ti4600, most of those cases are too small to fit one of those full length cards in easily. I'd go Ti4200 if you can find a good price.
CS 1.6 for steam needs much more power than 1.5 and under for some reason. I say get a Ti4200-4600.
I can vouch for a Ti4200's Performance, runs CS 1.6 no sweat. Hell, I play CS:S on it....and I get ~60fps with 2xaa and high detail/models/textures....
some of that is because the ti4200 doesnt support dx9 shaders, so high detail doesnt really matter in that situation
