Syberdeath
- Feb 9, 2005
I have a dell latitude c810 and it has a strange problem i have never seen before.
i turn on the laptop and it works fine, acting normally, for about 1-2 minutes usually. all of a sudden it shuts off. you can be doing anything in windows and bam your looking at a black screen. it does this like you pulled the plug out and cut the power.
when i try to turn the laptop back on after this happens it wont even get to the windows load screen before it shuts off. the NEXT time you try to turn it on after that it wont even get finished with the dell post screen. the NEXT time you try to turn it on after that, the power light just blinks or it wont even blink at all and the screen doesnt display anything.
if you wait 10 minutes it will start up normally again and it gives you the original 1-2 minutes of working time before it shuts off and the chain starts all over again.
i have tried using the laptop in my dock station, i have tried taking the battery out and only using the power cord, i have tried using only the battery power and no power cord, i have checked the bios settings as well as i could in the operating time it gave me and they have not changed from last week when everything worked normally and the laptop could stay on like a normal computer.
please help i really need all the files on this laptop! lots of important work and all.
