puntadigital
- Jun 7, 2007
Hi there
I'm pissed off right now - I bought a cheap HTPC case to host what used to be my main rig -
everything went smoothly until I had to clear the CMOS - after that I have the bios screen and
everything is detected - IDE drives-Ram and the right CPU put it says like the default values where loaded , pressF1 to continue or DEL to enter Setup, but my keyboard doesn't respond, a regular PS/2 , I've tried 2 different keyboards and they worked in another PC - I bought a Saitek Eclipse USB keyboard, but I think USB keyboard is only enable at OS level by default, not at BIOS level.
what I can do ? there's any other info that you need in order to help me here ?
Mobo Abit IS7-E V1.2 - P4 2.8 - 1gb Kingston DDr400
thanks in advance
thanks in advance
