PLEASE HELP ME!!!
CJL18
Hey guys sorry this has nothing to do with gpu's, but i need fast help!
i have a dell optiplex gx1 and need to know if i can put pc133 ram into it.
the system itself has 100mhz fsb and pc100 ram. but it might still be compatable.
can anyone please help me? :confused:
if the voltage of the ram is the same, it should be fine. The pc133 ram will run at pc100 spec. edit: Make sure you don't buy sticks with high density ram, unless it's supported.
thanks for the help!!!
but this is the only info about the computer i can find.
http://support.jp.dell.com/docs/systems/ban_gx1/specs.htm
do you know if this would be able to use high density or noT???
(my version is the best one (p3 600)
