okay heres the deal, my computer always is saying its at 100% cpu usage and is EXTREMELY slow! does anyone have any ideas of how i can fix this problem?!?!? Thankyou!
If system idle process has 99% then the CPU isn't at 100%. It will bounce around alittle but system idle process should be up near there most of the time.
If you see a svchost.exe and a "System" using most of your CPU power, this seems to be a new virus, of which is not being detected by the latest virus definitions. It is starting to worry me because more and more systems are getting this problem and the only way we are able to fix it is by reinstalling XP Sheesh.
