einmannbude
- Aug 16, 2014
Hey there,
I am still new to water-cooling, but gained some experience with building custom loops inside the NCASE M1. At the moment I have a Magicool DCP450 pump and reservoir combo hanging at the outside back of the case. An EK Supremacy EVO block on an Intel i5 4690k at stock settings, Magicool G2 240 Slim radiator at the side panel and EK Titan X block on the highly overclocked GPU.
I am concerned about the temperatures inside the case under load. Reservoir, tubing and fittings get very hot. I barely can touch them. I don't have the possibility to measure the water temperature, but I have the feeling it is not healthy for this parts in a long term. GPU temp is in the 60s and CPU hits 70°C when gaming. Ambient temperature is 22°C, so in the upcoming summer, this might get a problem.
Now there is several things, I am curious about.
#1
I installed two 140mm fans in the bottom of the case and elevated the feet. They are pushing fresh air into the case from the bottom up. This does not result in better temperatures at all. I assume that the GPU, which is big in size, is blocking the air flow, so much of the air does not come to the top of the case, but I expected at least some minor improvement. The side fans are also oriented as intake. This might disturb the air flow even more, but flipping them as exhaust, where fresh air rises from bottom to top and gets exhausted to the side resulted in even worse temps.
#2
The highly overclocked and 100% utilized GPU is still cooler than the not overclocked and not so utilized CPU. Why is that? I checked the mounting and thermal paste spreading several times.
#3
At the weekend I changed the setup to air-cooling with an Noctua C14 and Accelero Xtreme III. When going from idle to load, temperatures were rising pretty fast and going from load to idle lowered them pretty fast again. With my water-cooling loop temperatures are rising very slowly and lowering also very slowly. With the hot tubing and fitting, I assume, I have a water temperature issue here. Am I right, and what can I do about it?
The Magicool radiator has a fpi of 16. I ordered an EK SE radiator, which has a fpi of 22. It will arrive this week. I will test, if this helps. Also I can install the Magicool in the bottom of the case and see if this changes anything.
If you have any hints for me or can explain to me, why my loop is behaving like it does, I would be glad to hear from you. Thanks in advance.
#1
#2
#3
