I would appreciate some suggestions regarding my backup strategy for my home file server.
My question is whether my source drive (data to be backed up) and target drive should be on the same controller or not. I need to put this into context, so here's the rest of the info. (Please read on before telling me not to put the drives in the same computer.)
From now on, I will not be thinking of RAID as a backup solution. Instead, my idea is to continuously or periodically (and frequently) copy my data from a non-RAID source volume to a backup volume. I want to duplicate nearly everything (similar to mirroring in RAID), but I don't want files deleted off the source to be immediately deleted off the backup. And I want the volumes to be independent enough that a loss of data or corruption on one is not automatically and immediately propagated to the other (as it would be with RAID).
Because I want frequent backups, I think the source and target disks should be in the same computer. (This is a home server; it is OK if a hardware failure takes the server off line for a while.)
My server has an Areca 1220 (SATA controller) as well as motherboard SATA. Should I ensure that my source and target drives are on separate controllers? Will there be a big negative performance impact if I use separate controllers compared to putting both source and target on the Areca?
And, btw, what software will help me backup as I have described. I'm running Ubuntu. Here is my list of backup software solutions I've started looking at:
http://davestechshop.net/ListOfFreeOpenSourceLinuxUbuntuBackupSoftware
