So the other day my pc crashed b/c of the northbridge overheating.. \This time it did some damage to the ntoskrnl.exe file and probably the mbr. I rebooted into the windows recovery program and tried to run the fixboot command, this didn't work it gave me an error msg saying it could not complete the task. So i run chkdsk with the repair command. \After that ran and fixed some errors i tried to fixboot again, didnt' work. Now, I tried to see if I could plug in my drive to my laptop via a usb/sata hub and windows loaded the drivers for the hard drive but did not give me access to the partitions on it. I look under disk management and see there's the partitions but they no longer have the fat32 designation, just says healthy and the size of the partition(s).
For some reason i decide to plug the drive back into my pc and reinstall windows xp onto the 1st partition ~117gb (out of 1tb) probably thinking I could try and recover the partitions after I load into windows...
Anyhow, i scrapped that idea since it would best to try and recover the partitions with proper partition recovery programs. I tried a couple from the hiren's boot cd and they came up empty - cannot find the lost partitions, the programs say there's no partitions to recover. Also tried testdisk to recover said partitions but after scanning the drive, it did not show any partitions.
Can someone with expertise in this field give me an idea what to do next? I am open to sending the drive into data recovery experts, but would like to have a recommendation on one that won't cost me hundreds of dollars if possible.
Please help!!
Please help!!
