cdr_74_premium
- Oct 20, 2010
Last year I moved to Canada and I brought my tiny Mini ITX case. It used to house a Atom board, but I couldn't resist buying something else to put inside. So I bought a MSi Mini ITX MoBo, i3 CPU and 16GB of gaming RAM.
After a while, I also bought a ASUS gaming monitor. So right now I have this freak setup: a somewhat capable gaming processor/mobo and RAM, in a case that will never have a dedicated GPU inside... and a gaming monitor.
Well, time to fix that.
Basically WoW, and web/word processing.
Around CAD 250.
Canada.
Case, GPU and PSU.
Monitor, CPU, MoBo, RAM, HD.
6) Will you be overclocking?
No.
ASUS VP228H Gaming Monitor - 21.5" FHD (1920x1080)
As soon as possible.
9) What features do you need in a motherboard? RAID? Crossfire or SLI support? eSATA? Onboard video (as a backup or main GPU)? etc.
I already have everything I need on that front/
Yes. Windows 10. 64 bit.
Around CAD 250.
Canada.
Case, GPU and PSU.
No.
