Please help me Identify whats wrong with my pc?
Ladic
Ok so this is the second time this happens. Im using Win7, and I have opened and cleaned the dust out.
So here is the problem, I restarted my pc and right before it loads the OS it gets stuck and I get some weird corlors on the top of the screen.
Last time I had to wait a while and then it started working normally again.
Right now it has started to act up again.
Here are some pictures, the first one is a bit blurry, but the bios screen loads normal but before OS loads it gets stuck
When before the OS loads does it get stuck?
Can you press F8 to get the boot menu?
Do you see the loading bars?
Since you mentioned that you cleaned and dusted your pc, you may have made a loose connection somewhere. Check your connections again and see if everything is properly seated.
I left it at that screen for a while and after some time it restarted by itself and booted up no problem. But I worry that something might be failing in the pc.
The OS was not loading, however I could go into the BIOS. After the second screenshot it went to the 3rd screenshot and get stuck there.
It does appear that some hardware component may be failing. But, it also maybe that your boot file may have gotten corrupted.
There's too little information to determine the problem here. There could be numbers of reason for this. I suggest you follow the troubleshooting guide in the sticky then report back here with more info.
Well everytime it happens, I just leave it alone, and probably after a minute or 2 (with the screen looking like the picture above), the pc will restart itself and all will be fine.
I can play and do evertyhing pretty much normal, my pc hasnt crashed while playing any games or such.
It only happens every now and then.
