Please help me get VIVO to work.
I heard that VIVO allows the user to plug a VCR to the graphic card and record the movie from tape to a AVI or Mpeg file, i have tried using virtual DUB for this experiment but it doesn't seem to work it just give me a error message saying " No captured driver available" i got VIVO on my gigabyte 6600GT turbo force edition but the driver for VIVO does not come with the driver CD so i was wondering where can i download it and how to get my experiment done.
will Virtual DUB work for recording a movie from tape would anyone like to clarify that for me.
What your looking for is WDM driver (which gives you VIVO capabilities). It should be in your Nvidia folder already and set up when you installed your drivers for your card. Check device manager and see if you have any ! for your card (should be under sound). Then manually install the driver (point it to your c:\Nvidia folder).
Ok thanks for the help but i couln't find the driver.
Check device manager to see if the device is indeed installed already, again look under sound properties.
