Please Help me Get to Sleep. BSoD's inside.
FadedSpark
0x0000000A
0x0000007f
those are the only two recieved as of now. repetitive on boot, varying between the two.
first was recieved 1:02 am, just before i wanted to go to sleep. i just tried coming here to check up on things, and both FF and IE died. tried reinstalling from a setup file on the laptop im on right now, and then explorer crashed, followed by MSN when trying to tell people i would be right back. Only program to not crash was winamp, sound drivers are ruled out id say.
Steps taken so far:
Uninstalled video drivers. the 7950GX2 is so unreliable, but its all ive got. No dice.
Downclock the processor another 200mhz (was running 1.8 because its below a heating vent. it was fine temperature wise but i dont like the concept... ) to 1.6ghz. again, no change.
Relaxed memory timings from 2-2-2-10 2t to 2-3-3-10-2t, again, same situation.
Please save me. i dont have an XP disk handy, infact, mine is toast... ive got vista but I really dont want to go there. not to mention i REALLLLLLYYYY want sleep.
Thanks Doods.
Personally I'd advice you to go to bed and have a look at it tomorrow, there's no use in trying to fix you machine if you're dead tired...
THEN: I'd start out by running memtest on the system, if that fails then try testing with only one ramstick at a time...
