OK, I've limited my choices to the NEC ASLCD24WMCX and the Hyundai W240D. What I've been looking for is a 24" monitor that's relatively inexpensive (~$400-$500) that I can use for gaming/movies and to hook up my Wii through component. Now comes my question: Which should I get?!?!
Here is a list of the Pros and Cons for each monitor.
NEC:
Pros
Hyundai:
Pros
I know they're both TN panels, I really don't care about viewing angles that much.
In short, they're both basically the same monitor, just one has more features but is more expensive and is made by a 3rd party company. Also, I should note that the Hyundai uses the same panel as the Samsung 245B/BW.
Also, let me know if I missed anything or if I'm incorrect about anything. But mostly, HELP ME DECIDE!!!
NEC:
Pros
- Popular brand
- Relatively inexpensive (~$450)
- Can scale 1:1, 16:9, 4:3
- Easy to switch between inputs
- Lots of positive reviews
- No extra features
Hyundai:
Pros
- Better contrast ratio
- Better out-of-box calibration
- Truer blacks
- Lower input lag
- More features (Pivot, elevation, swivel, tilt)
- Comes with 2 USB ports
- Easy to switch inputs?
- Not a popular brand
- Overheats when it is turned on for the first time?
- More expensive (~$525)
- Not as many reviews
- Annoying touch-sensitive OSD buttons
