I am considering to combine a ASUS P6T WS Professional with one of the following SAS RAID controler cards:
At first the system will use three 1TB Seagate ES.2 SAS drives in a RAID 5 array. In long run I want to extend this to eight 1TB Seagate ES.2 SAS drives in a RAID 60 array. Because of this I don't intend to use the two SAS controlers on the ASUS P6T WS Professional. I might use them in the future for a fast RAID 0 startup solution. The operating system will probably be MS Server 2008.
I know the Areca card has more features (extra cache memory and out-of-band management), but I also know it costs a lot more. I want to know if its worth the extra money.
Further I would like to know if the Adaptec and the SuperMicro card will offer the same kind of speed and quality. The SuperMicro card seems to be a bit cheaper, but is it wise to buy one?
Finally I understand that the backup battery can be placed on the Adaptec card where Areca needs a separate slot for the backup battery card. The SuperMicro cards uses the optional battery backup unit BTR-0012L. I would like to know if this will also consume another slot.
Kind regards,
Ed R.
- Adaptec RAID 5805 http://www.adaptec.com/en-US/products/Controllers/Hardware/sas/performance/SAS-5805/,
- Areca ARC-1680ix-12 http://www.areca.com.tw/products/pcietosas1680series.htm,
- SuperMicro AOC-USASLP-H8iR http://www.supermicro.com/products/accessories/addon/AOC-USASLP-H8iR.cfm
Kind regards,
Ed R.
