Hardware:
Intel Core 2 Duo E4300
BIOSTAR TForce965PT
G.SKILL 1GBx2 DDR2 800 F2-6400CL5S-1GBNQ 5x5x5x15
XCLIO GOODPOWER 500W
ARCTIC COOLING Freezer 7 Pro
Problem:
Overclock Navigator Engine set to Manual Overclock
CPU Voltage: 1.350
FSB T Voltage: Default (1.2)
MCH Voltage: Default (1.8)
Memory Voltage: Default (1.8)
System Memory Freq: Default (Auto)
CPU Clock: 233Mhz - I get a little over 2GHz but if i go anything higher, nothing!
PCIE Clock: Default (Auto)
DRAM Conf: Default (Set by Spd) 5x5x5x15
TWR: Auto TWTR: Auto TRRD: Auto TRTP: Auto
Anyway, I have made other small changes to CPU Volt, Memory Volt, and I have tried 333MHz for the CPU Clock. The only one that works is the one above. Could someone please help me?
Thank you!
BIOSTAR TForce965PT
Problem:
CPU Voltage: 1.350
Thank you!
