Houston3000
- Dec 14, 2006
I had a thread a while ago where everyone here was very helpful in helping me choose which parts to order. I have never built a PC before though and just got almost all the parts today.
I just placed the processor (C2D E6400) into the motherboard (Gigabyte GA-965P-S3) socket exactly as the directions said in the processor manual. The processor socket lever required quite a lot of pressure after the chip was in there to close it, I know it was lined up correctly (had arrow facing the indented corner of the socket plus the pictures in the manual showed the same way) so was it suppose to require a relatively large amount of force?
Up until this point the mobo and processor manual have been the same, however the processor manual tells me to install the heatsink "with the MOTHERBOARD INSTALLED IN THE CHASSIS" (caps and all) while the motherboard manual tells me to do it right after installing the CPU before I place it inside my case (Cooler Master Centurion CAC-T05). Should I follow the big capital letters and place the heatsink in AFTER installing the motherboard into the case?
On the same token, should I install the RAM before placing the mobo into the case? I have installed RAM before into my past mobos while it was in the case so I assume doing it beforehand would just be a step of convenience.
