Please help, forgot to plug in hsf, temps reached 89c
sammieboy
Just bought the E6850 cpu today and popped it in... during my excitement, i forgot to plug in the plug for the heatsink fan....................i know... i'm an idiot...
3-4 hours later..... i decided to check temps and it read 89 deg celsius for both cores.... im like crap...........
after i plugged the fan in... temps are bck down to 36-39 range...
did i damage my cpu?
hope not.. =(
any opinions besides that i'm an idiot?
thanks!
The CPU would normally shut itself down before any damage could be done. Run ORTHOS small FFTs for at least 4 hours to see if you're chip is compromised (at stock settings).
Any reason you chose that CPU over the Q6600 and the E6750?
I would think you're ok...most BIOS by default have the PC shutdown if temps get too high...
As long as the HS was on properly then you might be good as your chip would have shut down if it got too hot. Now if you forgot the HS then one might throw the idiot tag around :p What were you using to check the temps btw?
If it's still running it should be fine. It would have throttled down/shut itself off if it got too hot.
I dont think the Auto shut down was enabled in BIOS.
I used PC Wizard 2008, dl'ed from CPU ID's site to check the temps.
Whether it was enabled in the BIOS or not shouldn't matter -- I think the chip will still auto shutdown if it has to.
Run ORTHOS like I said for some stability testing.
Use CoreTemp 0.95.4 to measure core temps.
89c is hot, but you should be fine. Silicon doesn't start breaking down until ~160C. Worse case, you may have shortened the life a year or two, but I doubt it.
