I just received my PS3 today and would like to hook it up to my monitor. I know the monitor is compatible with HD as long as I use the DVI. This is where I'm running into a problem. My computer currently uses the DVI. Is there a cheap solution to share the DVI port between the 2? The cheapest KVM I can find is around $75. Would I get a drastic loss of quality if I changed the PC to run out of the S-video into the monitor instead of running DVI?
Thanks in advance and any suggestions are welcome. My rig is in my sig.
