Please... Help deciding on a Mobo
motolube
I am new at this so bare with me... I do take good or bad comments.
I have been buying components for my new rig either from the FS/Trade forum or Hot Deals forum and it has been great but I think I have jumped the gun on some stuff w/o checking for compatibility first, hence, the Newbie comment.
Anyways, I can't decide on which mobo to go with and I need your help. Following the guide from New egg where they commented on Intel being a bit better than AMD when it comes to gaming I have selected 2 Mobos but I don't know what the differences between one and the other. I will be getting an Intel E6400 dual 2 core CPU 775
1.- ASUS P5N32-E SLI... The reason why I chose this one is because I purchased (2) BFG 7800 GTX OC from one of the members here and this Motherboard offers a FULL 16x by 16x SLI support. Newegg has it for $ 309.99
2.- EVGA 122-CK-NF68-AR... This one also offers the FULL SLI support of 16x by 16x and Newegg.com has it for $ 249.99
Now, here is where my confusion starts... I purchased already OCZ 2GB (2 x 1GB) Platinum DDR2 PC2-6400 800mhz 240-pin memmory and I don't know if it is compatible with either of those 2 boards. I have sent e-mails to OCZ, ASUS and EVGA and they haven't gotten back to me on it.
A.- FSB specs on the ASUS is 1333/1066/800mhz but on the EVGA is only 1333/1066mhz... I really don't understand what this mean but I thought I asked!
B.- CPU support on ASUS is Intel Quad-core CPU ready and on the EVGA, the CPU support is only Hyper-Threading Technology
The asus has a few other things that the EVGA doesn't have or bring but I don't particularly believe it will help me or hinder me in any way because I am not an Online player... again, I am saying this because this is as far as I can understand the changes.
Without even checking if I can get either board cheaper somewhere else, can someone school me on why the ASUS is more expensive than the EVGA and which one should I consider going with?
Thanks you very much and have a Happy Holidays.
Edit: I should also clarify that I am not an Overcloaker, never done it and I don't believe I will... just in case that helps. WOW, 19 views and Zero responses... do I smell that bad? :confused: :D
Why is the Asus more expensive? because that's how life is... Asus don't come cheap
Moving on...
Your ram should be compatible with both boards. Both use ddr2, which is what you have, and all motherboards are backward compatible with slower ram.
The Asus says "Intel quad-core ready." It is my understanding that this means that the board is capable of running a quad-core cpu, however it might require a bios update to do so. It also says that it supports Core 2 duos, so your cpu will work fine.
The evga says that uses "Quad-core/Core 2 Extreme/Core 2 Duo/Pentium" cpus, so your's will also work fine with it.
Both are good mobos, and your gear should work with both of them. If you're really going to spend that much money, I'd go with the Asus, but that's a lot of personal preference. You might also note that Asus makes a cheaper version of that board, the P5N-E. It doesn't run SLI in 2x16x, but if I recall, 8x will cause an neglegible performance drop.
The only issue I could foresee is that it is possible that, if you got the evga board, it might for some reason try to clock your ram to 1066. However a quick bios adjustment would solve that.
This'll be a nice rig when ya get it going, let me know if you have any more questions.
