Please help clear up inconsistent info on PWM IC's (function, temps, location, etc,)
Dew itt right
[( Please correct me where I'm mistaken or missing information! New info will be updated as it comes in. )]
*Updated 1/18 1pm! Thanks to soundx98 @ DFI-Street*
I'm hoping to find out (from somebody who REALLY knows what they're talking about) some accurate info on PWM IC's. I've done some searching and here's what I've found (reference board below)...
What is it? - Pulse Width Modulation Integrated Circuit
It actually consists of three parts
1. PWMIC - rectangular chip below VDimm MOSFET and to left of ATX Connector
2. The three MOSFETS with Heatsinks soldered to them
3. The sensor - to right of CPU and left of sinked MOSFETs
What does it do? - It controls/adjusts/filters voltages from PSU to supply the board components.
Where is it? - The circuit includes (1) the rectangular chip below VDimm MOSFET and to left of ATX Connector and (2) the three MOSFETS w/ HS's soldered to them. The sensor ids the small yellow "thingy" between the CPU and sinked MOSFETS.
What are some recommended temps? - __^C idle and 45-55^C at full load.
How do you lower the PWM IC temp? - I've only found two solutions for this: (1) Arctic Alumina or chromatics "tape" and heatsinks or (2) instal a small fan directed at it (most popular). This appears to be irrelevant unless your experiancing instability during high temps.
Reference board - LanParty nF4 Ultra-D
I pulled off my chipset heatsinks, cleaned and reapplyed some TIM, and my PWMIC temp dropped from about 48c idle to 29c. I did also add a 92mm fan blowing down over the ram.
Cant say that its really improved my stability or made much of a noticable change in board performance or overclock.
Original post updated - Nobody here at [H] has input?!
Temps would be nice. Anyone ever get instability due to high temps? What are the highest temps you've seen it at (stable or not)?
Not on this board, but I've seen power FETs on mainboards get so hot that they desolder and slide off the pad, I've also seen the aftermath of them having catastrophic failure, ie my K7S5A board blew the HEXFETs apart when the caps failed.
Check it out here: http://www.rhcf.com/sisubb/ultimatebb.php/topic/1/175.html
The FETs can take a decent beating, they usually have a fairly high rating amperage wise and heat wise.
The DFI board in your picture has a great looking power section, they look like good components. I wouldn't worry about them.
MD
Not worried, just curious. When I poked around in some forums, I found VERY different answers so I thought it be nice to know whats really going on.
For a while i was getting high temps on there 57-60c during full load and i was getting instabilties in my system. I wasn't even sure what those sensors were even for. I just decided to toss an extra 92mm fan over my memory, and voila, instant cooler temps nuthin over 47c now max under load. Also too my instabilities are gone, no more are those problems of crashers and errors in early testing. ( some in late tests but burn in isn't complete.... ;)
