?? Please help/advise
BrainC0DE
my friend needs a new mobo but doesnt want to get ddr ram or a new cpu yet just the mobo..
currently he has an athlon 1ghz + sdram. can you guys suggest the best mobo that can support that with the greatest upgrading cabability?
thanks to anyone with input..
check newegg under SDRAM boards
my personal favs running SD that still support Athlon XP's are:
Soltek SL75-KAV
MSI K7T2-Turbo2
he sure he doesnt want to upgrade? I bet it is the ever present $ issue. I understand too well.
Ok, those two boards seem fine - also look at the ECS K7S5A series - as they are cheap and will handle both sdram & ddr - now you will be limited to the 266 mhz bus - two generations behind ( 333, 400)
Now I know MOST will NOT RECOMMEND ECS. And for the most part I agree with them. This board is the one of the few exceptions I would recommend from them -
I had one (it did die on my when 3 yrs old) but it was a decent board - no overclock - no raid - the pro version does have usb 2.0...
as for Angry_Games, erm your are a DFI rep right? What is with the recommendation of other manufacturer boards? ;)
If it's just to have a running computer, yeah, ECS is fine, but beyond that I really wouldn't use them.
thanks guys.. how about if he went with a ddr ram + mobo.. would a athlon 1000mhz work ok on an asus a7n8x del + some ddr ram?
