Ok I have built a new comp and everthing works fine untill i try to install windows XP on it. It starts everything and all looks good till it gets to the part that you pick like continue to install, repair install, or quite without installing. after that screen comes up for about 1-10secs the monitor will randomly cut off and nothing works but my power led is still on. sometimes if i get lucky and hit enter REAL fast it will go to the next screen where you agree to terms and befor i can press F8 to agree, the monitor will cut off and does the same thing. I have tried XP home and Pro and both do the same thing. Please help!
