Rockfishbrewery
- Apr 20, 2011
Hello,
I'm setting up a 2GHz Core 2 Duo dedicated folding box, and I have a question.
1) Is it worth it to run the -SMP flag on a Core 2 Duo box? Or should I stick with running two separate instances of the uniprocessor client?
2) The motherboard I'm using has one PCI slot open, and I'm thinking about adding a 430 Fermi GPU. How many PPD can I get with a Fermi 430? Also, can I run both the CPU and the GPU F@H clients at once? Does running the GPU client in essence require a certain amount of CPU capacity?
Thanks in advance for any input.
I understand that a 2GHz Core 2 Duo isn't a huge performer, but every little bit helps, right?
