Please help: 70fps drops to 15fps every 5secs
I mostly use this computer for gaming bought it in Jan/07, and just recently about 2weeks ago, when im playing Cs:Source or WoW, my fps would go from 70 and then drop down to 15fps and it seems to happen every 5secs.
I notice it more in Cs:source, once it drops from 70fps - 15fps, its like a horrible lag for about 2sec then goes back up to 70fps. Which messes up game play big time
Is this a Video card or Power supply issue?
ps- sometimes a random line would just appear down the screen, here is a screenshot of what it did once
Your video card is undoubtedly overheating.
The messed up display you see is known as artifacting.
Post specs of your system please...
Its an HP Pavilon - A1630n (yes i know, but it was on sale for $650bux) and my pockets are not deep.
Amd athlon 64x 2
4600+ processor
2.4 GHz, 2gig ram
250gig hard drive
300watt power supply
was a stock Nvidia 6150 le, then buddy gave me his nvid 6600gt
ps - i have touched the video card and it is super hot, and i even removed it and used the Dust spray, no luck still =(
I had a problem similar to this with my system and running HL2 the fps would spike like crazy try turning the vsync option on. The messed up display might be a f**ked video card.
Amd athlon 64x 2
4600+ processor
2.4 GHz, 2gig ram
250gig hard drive
Is the fan still working? If not, might as well replace it unless it's under warranty.
I had a similar problem with my 6800GT.
I fixed it by removing the entire heatsink cover to find that the actual heatsink had dust caked on it which prevented the fan from blowing air where it should be. I removed all of that gunk and the fan was able to push air over the GPU heatsink thus curing the problem.
do these slow downs happen any other time,or is it a game related issue?the picture indicates video card problem but have looked at the harddrive going bad also.forgot about the power supply kinda wimpy.may want to invest in a newer unit.
thx alot guys i'll keep all that in mind. i'll most likely as someone above mentioned take the fan off the vid card , dust it and place it back on hoping it solves problem. if not new vid card and power supply, lol
If your card is BFG / XFX / Evga, call up their RMA department and see about a replacement rather than removing the fan yourself. Most likely your card will be upgraded if you send it in for a replacement since the 6 series is old and discontinued. If its MSI / one of the others, its probably not still warrantied, but you can always call and see :)
Take the side off the computer and put a desk fan blowing on the card. If that solves the problem, your card is overheating. If not, it needs to be RMA'd and, as mentioned, a new PSU wouldn't be a bad idea (300 watts is enough for that system, but you can't be sure of the QUALITY of those 300watts, which is the problem).
