jonathonball
- Sep 23, 2005
Right now I'm using an old no name ATX case I bought from a mom and pop shop in like 2001. It's a nice case for the era, the sides slide into place and are held in by a third peice that slides into the top.. one thumb screw, two slides and i'm in.
But all is not well... the case is too small and has too poor of airflow for my current setup.
Right now I'm using:
The previously mentioned case
8800 GTS 320 /w stock cooler
Core i7 920 /w stock cooler
P6T Deluxe /w stock cooling
CORSAIR XMS3 6GB (3 x 2B) DDR3 1333 /w stock cooling
250gb and 500gb sata drives
sata dvd burner
Corsair HX 620w PSU
Here's what I'm looking at moving into:
Antec 300
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=antec 300
8800 GTS 320 /w ARCTIC COOLING ACCELS1 Rev 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186016
Core i7 920 /w Thermalright "Limited Edition" TRUE Black Ultra-120 eXtreme
http://www.frozencpu.com/products/7..._LGA_775_LGA_1366_AM2_Xeon.html?tl=g40c14s757
everything else the same.
I'd like to stick with air. Don't really want to spend more than $200.
I built a pc for a coworker last month. He picked up the Antec 300 case.. it was well built, quiet-ish, had fan filters, and was CHEAP at $50.
I'm going with the ACCELS1 because it was well reviewed and is cheap (and i can't see spending too much on a cooler for a component that I'll probably replace before 2010.)
I like the Thermalright cooler because I think I might finally grow some balls and OC a little.
Thoughts? I'm ready to pull the trigger.
sata dvd burner
Corsair HX 620w PSU
Antec 300
