Please critique my build
anexsia
Hi, sorry to bug everyone with yet another build critique post but I'm about to purchase parts for a new build in a day or so and I'd like to hear everyones opinions on the parts I'm going to get. I already have a case and a some DVD drives. This new computer will be used mostly for gaming and I only have a budget of about $650. I'm only buying a Geforce 7300GT right now till hold me off with light gaming till I can afford a 8800gts
- GIGABYTE GA-965P-DS3 (rev. 1.3) - $99.99
- BFG Tech Geforce 7300GT 256MB (keep in mind i'll be buying a 8800gts soon) - $79.99
- Intel Core Duo E6600 Conroe 2.4GHz - $223.90
- GeIL 2GB (2 x 1GB) DDR 800 (PC2 6400) - $99.99
- Samsung SpinPoint 320GB 7200RPM Sata Hard drive - $79.99
- ENERMAX Whisper II 535Watt PSU - $79.99
Total: $663.86
Also has anyone used the Bill Me Later option at Newegg? I have good credit and paying it off won't be a problem as I have most of the cash, just wondering if the Bill Me Later option is an ok method to use. Thanks again!
Looks good. I hope you can get the 8800 soon, it'll be a sweet rig. :)
However, I can't help you on the Bill Me Later feature.
Yeah, looks fine. The only thing I would change is the ram. This set is $10 more, but it has D9 D9GMH IC's, which are alot better then the SpecTek ones that Geil ram has when it comes to oc'ing.
For $702.04 (includes Shipping) plus a 25 MIR making it $677.04 you can make some changes and get you 8800GTS now and not reduce your overall performance much....
The DS3 is a great board to build upon i would keep that...
HD SEAGATE has better Reliability and Warranty than Samsung Drives...
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3320620A 320GB 7200 RPM 16MB Cache IDE Ultra ATA100 Hard Drive - OEM $79.99
http://www.newegg.com/Product/Product.asp?item=N82E16822148139
VID CARD Leadtek PX8800 GTS TDH 320MB Extreme GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail $259.99 after $25 MIR
http://www.newegg.com/Product/Product.asp?item=N82E16814122022
PSU XCLIO GOODPOWER 500W ATX 500W Power Supply (Very nice PSU with SLI Support) I Own it and have had zero problems... $49.99
http://www.newegg.com/Product/Product.asp?item=N82E16817189005
PROC
Intel Core 2 Duo E4300 Allendale 1.8GHz 2M shared L2 Cache LGA 775 Processor - Retail (easily OC's to 2.8 and higher...Has high Multiplier and easy to OC with cheaper ram...) $114.50
http://www.newegg.com/Product/Product.asp?item=N82E16819115013
MEMORY you don't need DDR 1000 to have a fast machine...the e4300 9x with 667 ram gives you a proc running at 3ghz... OCZ Value Series 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Dual Channel Kit Desktop Memory - Retail...(this ram is most likely good up to 800mhz) $58.49
http://www.newegg.com/Product/Product.asp?item=N82E16820227060
DDR2-800 is so cheap lately ($90 or less for 2GB kit, sometimes without MIR -- look at Corsair and G.Skill in particular) there's really no reason to buy 667. All depends on what processor you plan to use, of course.
Well i agree if he decides to get a proc with a 1066 fsb that ddr 800 is important...On the other hand if he gets the e4300 with a 800fsb by default he can OC it very easily with 667 and the extra money spent on ddr800 is a waste since his budget is 650....the difference between 58 and 90 is pretty large considering the fact that most 667 ram will easily oc to 800 anyways... again ddr 667 runs at 333 and the e4300 has a multiplier of 9...making it 3ghz..pretty nice for a $115 dollar chip...
All true.
Thanks for all the great replies, you all have helped me out a lot I'll be making some changes tonight and ordering :).
