Please critique my build
Marciff
Intel Core 2 Duo 6600
Intel D975XBX2KR (Bad Axe 2) motherboard
OCZ DDR2-800 PC2-6400 Platinum XTC DC Rev.2 2GB
Seagate Barracuda 7200.10 16MB 400GB SATAII
BFG GeForce 8800GTS
Lian Li PC-A05 Black
Will I be able to use my Antec NeoPower 480W Power supply?
Is the onboard sound any good?
What do you guys think?
-Kevin
Do you plan on running crossfire at all? If not, go for a P965 Express board instead. The P5B-E is a good choice, as well as the Gigabyte GA-965P-DS3. How old is the Antec Neo 480W? If its somewhat old, I'd suggest a new one. As for the onboard sound, I'd suggest trying it before buying a soundcard. If you don't like it, then you can always add a sound card in later.
the antec 480w won't power a system like that....well it could but with all those expensive components i wouldn't even risk it. i would go with the 700w OCZ gameXstream or something similar.
Not going with multiple video cards? Corsair HX 520. it's $106 shipped at zip zoom fly.
