memphis_1220
- Aug 28, 2004
Hello.
Just had my student loan through and can now afford a water cooling setup. I have done a fair bit of research but want you're opinions.
This is for the comp in my sig. Here is the setup (from over-clock.com);
Danger Den Maze 4 A64 Lucite Top - £38.23
Danger Den Maze 4 Acetal GPU block - £33.46
Eheim 1250 pump - £45.41
ThermoChill HE120.2 radiator - £58.56
Danger Den Single 5.25" reservoir (unless it is difficult to bleed/fill) - £22.71
Criticool PowerPlant PCI relay - £23.89
Water Wetter
Tygon 1/2" tubing
Other barbs (plastic, nylon or brass?)
2 120mm Deltas
Total is around £255
- 2%
- £12 (kit discount)
£238
Thanks for any replies
Mike
Water Wetter
Tygon 1/2" tubing
2 120mm Deltas
- 2%
£238
Mike
