Please check my CPU-Z readings
Nom Anor
Friend did some overclocking for me (all air)
What do you think?
My CPU ic 69°C Idle. System shuts down in 3Dmark06 when testing CPU.
On iTAT full load it reaches 85°C and shuts down too.
Help me out plz. :eek:
RAM: A-Data DDR2 1066Mhz
What kind of hardware are you using? What is your HSF? Your temps seem really high for that OC.
yeah, i reseted the HS and now everythings fine.
48C idle
any tips on the overclock? or does it look ok?
It's a decent overclock, but with good cooling I'm sure you could take it higher. What heatsink are you using? If you're on stock, you'll want to get a better cooler if you're serious about overclocking your CPU to its max.
Holy shit, 1.4v indicated on CPU-Z? My Core2 runs at 3.8ghz on 1.2v indicated on CPU-Z.
What is your real voltage?
Because. In CPUz to get 1.4v you need about 1.45v in BIOS.
You don't need that much voltage. Drop it down to 1.35v in the BIOS and check for stability, increasing as necessary.
hello newbie here i have e6600 clocked to 3.132 (348) FSB. but in xp if i chek asusprobeII
it says my vcore is going from 1.4-down to 0.98 is this a good/bad or normal? my mobo is
a P5LD2-VM SE ram set at 697 pci-e at 118. plus i cant get FSB any higher (wont post)
smoke
