Please assist with new build =P
NEW BUILD
I am trying to finalize my gaming box, but I wanted to double check with the forumers one more time to get some final tips :) I hope to overclock the e8400 to whatever levels are safe with air coolers, and I primarily will be using this for gaming. Thank you.
Case - $74.99
RAIDMAX Smilodon Extreme Black ATX-612WEB SECC STEEL ATX Mid Tower Computer CaseNo Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078
I like how this case looks, and the newegg reviews are good, and SharkyExtreme gives it a good review.
Motherboard – 189.99
GIGABYTE GA-P35-DS4 Rev. 2.0 LGA 775 Intel P35 ATX Ultra Durable II Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128064
Hardforum users seem to give this good reviews and it will work oob w/ my e8400.
CPU – 240
Intel Core 2 Duo E8400
gaming power for the price
GPU – 269.99
EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130325
Good for now (only 30 dollars more than a GT), and I hope to utilize EVGA’s 90 day upgrade for a 9800gtx when they are released anyway.
HD -49.99
SEAGATE ST3250410AS 250GB SATA 7200 RPM 16MB Hard Drive
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005934
Plenty of space for my needs at a good price.
RAM - 114.99
OCZ Reaper HPC Edition 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
-some people have been saying go with cheaper ram, but its so cheap anyway I figured OCZ is as good as any.
PSU – 138.99
Corsair HX Series CMPSU-620HX 620W Power Supply
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=373110
-good psu, maybe a little much, but it is a good price, and if I upgrade I want to have plenty of power.
Monitor-309.99
Samsung 2253BW Black 22" 2ms
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001268
2ms response time.
Prices
220
269.99
114.99
189.99
138.9
74.99
49.99
309.99
Total
1368.84
I looked for cheaper deals, but I couldn't find anything better than these prices... How does it look for that price? I could probably trim the fat on the PSU and RAM, but I like the choices I made. Again, thanks for the info.
PREVIOUS BUILD
Hey, I have a $1300.00 budget for my gaming/general use computer...mostly gaming.I haven't been in the loop for awhile, but I have been researching and trying to find the best fit for that budget to play games with reliable hardware. Here is what I have so far... The only thing I have actually purchased is the E84800...everything else is still up for change.
CPU Intel Core 2 Duo E8400 (3.0 GHz, FSB1333, 6 MB L2) - $220.00 @ Puget
GPU EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB - $269.99 @ newegg
RAM G.Skill 4GB DDR2 1000(PC28000) - $99.99 @ newegg
MOBO GIGABYTE GA-P35-DS3L - $89.99 @ newegg
PSU CORSAIR CMPSU-650TX - $109.99 @ newegg w/combo
CASE LIAN LI PC-A05B - $89.99 @ newegg
HD Seagate Barracuda 250GB 7200 3.0Gb/s - $69.99 @ newegg
DISP. Samsung 2253BW Black 22" 2ms - $319.99 @ newegg
Cool Artic Silver 5 Thermal Compound - $5.99 @ newegg
cool ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - $26.99 @newegg
MIR - 20 on Samsung, 30 on EVGA, 20 on PSU
Questions -
Do I need to buy the EVGA directly from EVGA to take advantage of the 90 day return for upgrade option?
Can I save money anywhere?
Should I wait a few weeks for any significant price drops/new releases?
General suggestions are appreciated. Thanks for the time.
[/SIZE]
No, you do not have to buy directly from EVGA to take advantage of the 90-day program. Just register with EVGA after you receive the graphics card and your all set. Make sure you keep receipt so you can show how much you paid for the graphics card when or if you step up.
you could go with a lesser wattage power supply like the corsair 550vx.
if your getting 4gb of ram, make sure its 2x2gb because it runs less power than 4x1gb of ram.
since your not on a low budget, you should get a case with intake/exhaust fans. the coolermaster 690 is in that price range.
are you planning to overclock? if not go with the stock cooler. if your are then spend a little more and get this. ZEROtherm Nirvana NV120 120mm. it should get the e8400 to 4ghz.
and if your overclocking get the ($85) 2x2gb g. skill ddr2 800mhz instead.
look around at different sites for cheaper deals. clubit, buy, zipzoomfly, frys, to name a few. for example you can find the GIGABYTE GA-P35-DS3L rev. 2.0 at clubit for $83.
If you're planning on overclocking the E8400, you need a better CPU cooler than the AC Freezer 7 Pro. But if you plan on pushing the FSB past 400MHz, you will need to either buy a northbridge fan to cool off the northbridge or get a motherboard with better chipset cooling, like the MSI P35 Neo2-FR. (Go with the MSI board.)
If you're looking to save money elsewhere, consider crhscoog's advice and look for a cheaper case. Make sure the case that you do decide on has adequate cooling, which is best obtained with 120mm fan slots. Here are some options under $90:
Cooler Master Elite 330 RC-330-KKN1-GP ATX Case - $40
Cooler Master Centurion 534 ATX Case - $50
Cooler Master Centurion 532 ATX Case - $55
Cooler Master RC-690-KKN1-GP ATX Case - $62
Cooler Master Mystique RC-632S-KKN1-GP ATX Case - $85
$640 ($40MIR) - XFX nForce 680i LT SLI Socket 775 Barebone Kit
_____________ Intel Core 2 Quad Q6700 2.66GHz OEM,
_____________ 320GB SATA HD, 20x DVD±RW
_____________ 2GB DDR2 PC6400
_____________ ATX Mid-Tower Case
______________750 Watt Power Supply
$30 - Kingwin Revolution H.D.T. (Heat-pipe Direct Touch) CPU Cooler RVT-12025, for Intel LGA775 and AMD Socket AM2/754/939/940 CPUs
$204 ($40MIR) - Galaxy KFA2 GeForce 8800GT 600MHZ 512MB 1.8GHZ DDR3 PCI-E DVI-I HDCP HDTV Out Video Card
$300 - Soyo 24" 24DYLM24D6 Widescreen LCD Monitor
$1378 - $120MIR
Thanks Abu, I will probably get that Kingwin Revolution. That would work, but I don't want to do SLI since I plan on upgrading to the 9800gtx when it comes out, plus I've already purchased my e8400. Interesting build though, those 8800gt(s) are cheap.
In that case:
Mobo:
This is all you need, unless you need the extra features of higher end boards:
$90 (FS) ($30MIR) - ABIT IP35-E LGA 775 Intel P35 ATX Intel Motherboard - Retail (Apply coupon MB311FS)
Cooling:
The Kingwin is nothing but a rebadged Xigmatek HDT-S1283, the #1 ranked HSF at frostytech.com. The only difference is the fan used.
RAM:
DDR2-800 RAM will limit your overclock to 3.6GHz. If you are looking for more, try DDR2-1066 kits:
$43 - 2Gb Kit (2x1Gb) PC2 5400 3-3-3-8 D9GMH (very overclockable)
$70 - 4GB DDR2 PC6400 DUAL A-DATA (cheap, but only DDR2-800. You may try overclocking it though)
$100 - G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail (Perfect. Provides enough headroom for 4.5GHz)
GPU:
Bear in mind that the specs of the 9800GTX indicate that it's nothing but an overclocked 8800GTS 512MB that supports tri-sli. Also, the 9800GX2 is two 8800GTS' on a single slot, same idea as 3870 X2.
http://www.gpureview.com/show_cards.php?card1=559&card2=548
PSU:
For single-gpu setups, this is all you need:
$85 ($20MIR) - Corsair VX 550W ATX Power Supply - CMPSU-550VX
Albu, are you saying the fan on the rebadged Kingwin is better than the Xigmatek?
