XLeezardx
[H]ardChef
- Apr 30, 2005
http://videogames.barnesandnoble.com/GSPlatform_cds2.asp?PID=13427&z=y
$100 cheaper than game stops bundle
You know you can replace the hard drive with any other laptop hard drive... right?lopoetve said:it's only the 20g. wtf?
DriveEuro said:You know you can replace the hard drive with any other laptop hard drive... right?
ShLoNkY said:You can probably still Ebay this bundle and make a few hundred bucks. I'd say this deal is as HOT as it gets considering the demand for these.
Wouldn't be my first choice of games and its not 60GB..... I say throw it on ebay.
JCJones86 said:it's only the core system. wtf?
Because demand is lower for the lower-end models, I'd assume.
lopoetve said:point made. They're getting lower on ebay too
I'll bet a good percentage of the ones on auction now are re-lists from non-payers...I don't let non-payers off the hook and if more sellers would do this the problem would reduce signifigantly. Sellers are just afraid of retaliation feedback..RooK said:been lots of non-payments on a lot of those bids that went over 2500
if you work with ebay, it's not a problem. they simply eliminate the scammer on thesejoemama said:I'll bet a good percentage of the ones on auction now are re-lists from non-payers...I don't let non-payers off the hook and if more sellers would do this the problem would reduce signifigantly. Sellers are just afraid of retaliation feedback..![]()
