Playstation 2 + Turtle Beach Montego DDL.
I have the above card on Windows XP Pro (32-bit).
I have an s/pdif cable running from the optical out on my ps2 to the s/pdif-in on my sound card. I have digital out turned on my ps2 (tried this with digital out turned off as well). If I run sound recorder I can only hear the audio after I've stopped recording it when I select the s/pdif-in as my device (not in real time). Is there a way I can hear the audio while I'm recording it rather than after the recording is complete?
Huh. Somehow I missed that there's an optical port on my PS2. Thanks. :eek:
I vaguely remember running into a similar quirk with Sound Recorder a while back. I can't recall if it was something I was doing wrong, or if I just needed a different program. Have you tried a different program yet?
Also sometimes there are passthrough settings and so forth to worry about with S/PDIF.
Don't know exactly how that card's drivers are but with other CMI based cards there should be options to "Enable Monitoring" of the signal or something similar that ought to let you hear it at all times.
