Playing sounds from PC in voice chats
JHefile
Necrophilia Makes Me [H]ard
Sup
I hear some people do this. Playing online games it seems some can play wav files so all can hear. Besides putting a mic up to a speaker can someone give me some tips how to play from a file though the sound card to the game mic output?
I am not sure the directions are 100% correct, but if I recall from memory correctly:
Not sure about other sound cards, but Sound Blaster has for a long time had an option called "What U Hear" under the Recording tab in the sound control panel.
Then you also need to enable "Listen to this device" under the microphone properties under the "listen" tab. Oh BTW, this is for Win7/8 computers.
When you record from the "What U hear" source, it should capture everything.
