playing from a USB key
arr4ws
i wonder if its possible to install a game on a totally on a USB key and play it while plugged in...
i do not know if its should be in this forum... but i do not know where to put it...
I guess in theory it would work. After all a USB key can act like just a nother drive. The problem is if you are planning on playing the game on other PC's it may not lt you do that as sometimes the game needs registry entries created by the installer.
My friend used to play WoW off his iPod, so I don't imagine it to be much different only that the load times are going to be brutal but everything else should be fine since it will then be running it from memory.
Yeah, this would be your only problem. Sometimes games will automatically recreate that entry and sometimes they wont.
yeah i just bought a 4 gig usb key and im loving it so far... thanks for the heads up!
I have played WoW off a 8gb USB key.
Took longer to load - after that wasn't so bad.
nope im not gonna lose my job ... im just on the go a lot .. so its great to be able to play games on my not so great notebook
