Platform Specific Case??
Suprnova04
I just bought the lian-li pc-60 case. I was planning on putting a AMD 3500+ based system into it. I noticed just now that it says on the front "pentium 4". I can't think of any reasons that a case would be platform specific.. are there??? Thanks.
It just means that it meets the cooling requirements set by Intel. Shouldn't be cause any problems when installing an A64.
Its an ATX case and you *have* an ATX motherboard. There is *no* issue since AMD does not make either an AT or BTX motherboard for the any of their mobos.
as others said, you will not have any problems. case is made for ATX motherboard, as long as you get ATX motherboard, you are fine
