I wanted to aks you what is important for a plasma TV because i just found one for 1300 euro at a local store and want to know if it is ok.
Model: PDP 42 PHS ( 107 cm - 16:9)
Optical Performance
Brightness 1000 cd/m2
Contrast 3000:1
Aspect Ratio 16:9
Resolution 1024*768 @ 85 Hz (pc mode)
Resolution compatibility:
852*480 832*624 848*480
800*600 640*480 720*400
Viewing Angle 160/160
Color 16,7 million
Tuning
PAL / SECAM / BG / LL / NTSC
Internal Embedded Multisystem Tuner
Direct Channel Selection
Automatic tuning system (ATS) euro plus
Display formats 4:3/16:9 Fit to screen zoom - user zoom
Progressive scan via DVI
Digital Motion De-Interlaced
Digital Comb Filter
Digital Noise Reduction
Anti-Flicker
Non linear scaling auto scaling
WSS (Auto scaling)
V&H Position Contrast
Sharpness, Brightness, Contrast
2-tuner PIP, PAP, PAT
Sound
Built in Tuner
Sound output 2*7 W (RMS)
5 band equalizer
6 Preset sound modes
Connections
Euro-Scart socket (2x)
S-Video in, CVBS in-out
DVI-I, VGA
Audio in-out, Speaker output
Teletext
Teletext 800 pages/ Fasttext
Electronic
Program naming auto & manual (5 char)
SWAP / Intelligent channel switch
Automatic volume levelling (AVL)
Program Memory 99/5AV
On - Sleep timer / Clock Function
Child Lock
Multilanguage Graphical OSD (24)
Physical Aspects
TV Dimensions:
1072mm x 99.6 mm x 670 mm
Box Dimensions
1263 mm x 288 mm x 839 mm
Net weight tbc kg
G ross weight tbc kg
this are the specs from the plasma tv i want to get.
could you please tell me what are god values for a plasma tv and i know there are better ones i just want to know if the tv picture looks good and sharp with this one
thanks
Optical Performance
Contrast 3000:1
Aspect Ratio 16:9
Color 16,7 million
Tuning
Digital Comb Filter
Anti-Flicker
WSS (Auto scaling)
Sound
Built in Tuner
5 band equalizer
Connections
DVI-I, VGA
Teletext
Electronic
Child Lock
Physical Aspects
TV Dimensions:
Box Dimensions
Net weight tbc kg
thanks
