After seeing Kyle's post on the main page about playing Doom3 on his HDTV monitor, I got to thinking that when I build a system scheduled for December, I would like to use an HDTV monitor as my sole display if that is possible. Correct me if I'm wrong, but as far as I can tell if you have S-Video out on your video card, you can use an HDTV monitor as a computer monitor. Would there be any problems with only having an HDTV monitor?
Well, as I was loitering through the Wal-Mart electronics department, I compared all of the monitors and found one that I would love to own. It just seemed to have the best picture of them all. I don't know much about the technology, but I understand that there are different types such as LCD, projection and plasma (which I thought was LCD). Other than reading that projection didn't make a good computer display here in the [H] Forums, I don't know what would make a good display. Below are the specs. Would I be able to use this as the sole monitor for a computer? Would it be a good candidate? Suggestions, comments and advice are welcome. Also, I looked through the archives, but I couldn't find that post by Kyle? Could some one post the link here? Thanks.
Sanyo PDP-42H2W 42 in. Plasma HDTV-Ready Television: Tomorrow's technology today reduces reflections from room lights and windows for outstanding quality images. The "True Flat Screen Picture" creates a clean, natural, distortion free picture from corner to corner. 1080i native resolution is 1,024 horizontal x 1024 vertical with over 1 million pixels in 16 million colors, a 160 degree wide viewing angle and overall picture brightness enhanced to 1000 cd/ m²!
Key Features
Flat Panel Type Plasma
Screen Size 42 inch
Digital TV Standard HDTV Monitor / HDTV-Ready
Display Resolution 1024 x 1024 pixels
Display Capabilities
Display Format 1080i (HDTV)
Digital TV Standard HDTV Monitor / HDTV-Ready - Requires separate receiver to view HDTV signals.
Built-in Tuner SECAM, PAL, NTSC
Aspect Ratio 4:3 Enhanced, 16:9
Remote Control
Remote Control Standard
Image Quality
Brightness 1000 cd/m²
Output Color 16 million colors
Viewing Angle 160 °
Audio Features
Audio Type Virtual Surround
MTS Stereo With MTS Stereo
Secondary Audio Programming (SAP) With SAP
Technical Features
Parental Control Proprietary
Sleep Timer With Sleep Timer
Connectors
Rear Input Connectors Audio (RCA) x 5, Composite x 3, Component x 2, S-Video x 3
Rear Output Connectors Audio (RCA) x 1, Composite x 1
Headphone Jack With Headphone Jack
Speakers
Number of Speakers 2 Speakers
Speaker Power 2 x 10 Watt
Dimensions
Width 48.5 in.
Depth 4.7 in.
Height 27 in.
Weight 95 lb.
Miscellaneous
Included Accessories Remote Control Batteries
MPN pdp42h2w
Product ID 22342360
Key Features
Screen Size 42 inch
Remote Control
Image Quality
Viewing Angle 160 °
Audio Features
Technical Features
Connectors
Speakers
Dimensions
Width 48.5 in.
Depth 4.7 in.
Height 27 in.
Weight 95 lb.
Miscellaneous
MPN pdp42h2w
Product ID 22342360
